o2 sensors and temp switch location
I believe the pre cat 02 sensors are on the header pipe that comes down from the block, not shown.
Temperature switch? You mean to pre heat them? I imagine it just blasts it with current for a pre determined time, but not sure.<ul><li><a href="http://www.audipages.com/Tech_Articles/auto_transmission/transealreplacement.html">See post cat pictures here</a></li></ul>
The code says sporadic fault and the o2 sensors are also throwing up faults.
Can these be related?
Right bank probe says sporadic fault and left said electical curcuit fault[may be loose wire?]
