'99 A8 Water continues to get into the engine control module
Thanks in advance,
Oscar
If not, it's coming from somewhere below and coming up.....
If it's not sealing with the factory seal, then something is either wrong with the sealing surface of you need a new seal.
My first bet would be that the two are not mating correctly.
Trying to clean the ECU, I bent 1 prong and almost broke another.
Now I have a continuos check engine light that cannot be turned off.
Should I buy a new ECU and change the plugs that connect to it?
Any suggestions?
Thanks,
Oscar
