A8 2.5TDI Quattro - problem
Old Oct 9, 2005 | 12:46 AM
Aleko's Avatar
New Member
Default A8 2.5TDI Quattro - problem
Hello friends,
3 days ago I bought an Audi A8 2.5TDI Quattro with AFB engine. Now I have a problem with this car. VAG Com send error code 00550 "Start Injection Regulation" - the car underline all transmision and tiptronic go in emergency mode.
Diesel pump give information about not enough pressure! What is the problem with the car?
2nd problem is that the turbo charger give over pressure in the collector!
What is the solution to fix this problems?
Old Oct 9, 2005 | 05:06 AM
PaulW's Avatar
Default You might want to try tyresmoke.net
Since you are the ONLY diesel owner that I have ever seen here, (most of us are in the states) try tyresmoke.net
Wish I could help, but have no idea.<ul><li><a href="http://www.tyresmoke.net">http://www.tyresmoke.net</a</li></ul>
Old Oct 9, 2005 | 05:08 AM
tozoM8's Avatar
Tech Guru
Default We don't know much about diesel here, but I would check the fuel filter.
If you were very low on fuel, it can have air bubble in the system. Try to fill up your car and prime it. There should be a little primer pump under the hood by the fuel line. Good luck!
halfers
Audi A3 / S3 / RS 3
17
Nov 6, 2025 07:37 AM
2008 S-LINE
A4 (B7 Platform) Discussion
106
Jun 8, 2016 11:30 AM
saq
Audi A3 / S3 / RS 3
Apr 21, 2004 04:43 AM
fjarnjak
Apr 18, 2002 02:38 PM
dresch
Misc. Models Discussion
Nov 12, 2000 06:38 PM
