What would be the easiest way to add fluid to the tranny?
Old Oct 13, 2005 | 10:39 AM
Acceler8's Avatar
Old Oct 13, 2005 | 10:48 AM
ivans A8's Avatar
New Member
Default I believe there is only one way.
And it is under the car. You have to do it at certain transmission temperature (35-45 C). And fill it until it overflows. Check audipages.com for more detail.
Old Oct 13, 2005 | 11:20 AM
Acceler8's Avatar
CMIIW, but I thought you could do it through certain hoses.
Old Oct 13, 2005 | 12:48 PM
tozoM8's Avatar
Tech Guru
Not on yours, 97'-99' only.
Old Oct 13, 2005 | 01:42 PM
Fulliautomatix's Avatar
Member
Default You don't say... on a 97-99?
I've never read that procedure, can you point me in the right direction?
Old Oct 13, 2005 | 01:51 PM
tozoM8's Avatar
Tech Guru
Default That is not really a procedure. You can add fluid trough the breather hose, but....
it will go very slowly and you still need to check the level. So it is possible, but almost just theoretically.
Old Oct 13, 2005 | 05:31 PM
Acceler8's Avatar
bummer, so fill plug it is
Old Oct 16, 2005 | 07:23 AM
-OvO-'s Avatar
Default I'll give you hand...
if you have the VAG tool. I did mine with a funnel and long hose for the first couple of liters. Easier than pumping. I have a little manual pump and a spare liter of fluid for the last bit.
 Pouria Savadkouei
 Michael S. Palmer
anolin
May 23, 2007 06:52 PM
SmokinM3
Audi 100 / A6 (C4 Platform)
May 2, 2004 11:08 AM
RxFX101
Dec 20, 2003 11:14 AM
germantoy
Audi Original "S" Cars
Oct 16, 2003 05:06 PM
crakerhead
Nov 8, 2002 09:42 AM
