Fuel Tank repair, I would prefer to not disconnect battery.
Old Jan 31, 2007 | 05:25 AM
albundy3670's Avatar
Default Fuel Tank repair, I would prefer to not disconnect battery.
My wifes 98 A8 has a fuel leak either at the filler neck or expansion tank, I'm pretty sure of this because the only time it leaks or smells is when we would fill up completely, so now we just put in about 15-16 gallons when we fuel up and that has eliminated the leak. I've looked in the Bentley manual to repair this leak and they say to disconnect the battery. Please give me feedback on disconnecting the battery, it scares me a little because I fear that after I reconnect the battery something that used to work won't. If diconnecting the battery is precautionary only to prevent spark, I would much rather take that chance than disconnect the battery and wish I didn't. Any feedback would be appreciated. Thanks, Mike.
Old Jan 31, 2007 | 06:07 AM
JimR's Avatar
AudiWorld Uber User
25 Year Member
Default Two things.
1) I'm pretty sure it's precautionary.
2) Are you sure it's not the sending unit seal, which is accessible through the trunk. This is a common failure, and generally causes the MIL to light up with a standard code, probably 16826 & 16839, EVAP Emission Control - Small Leak / Large Leak.
See Audipages for a procedure for 2).
Old Jan 31, 2007 | 06:57 AM
Default Re: Two things.
Thanks Jim, nice car by the way, I have a 97 Pearl White A8 myself. I ran the Vag-com on the wifes car and did not come up with any codes, I will run it again to be sure. The leak is big enough that it stained the garage floor, not flowing by any means, the fumes are bad though and need to fix it because I have little kids. Thanks for your input, appreciate it, Mike.
Old Jan 31, 2007 | 07:05 AM
ex-a8drifter's Avatar
I would say its pretty common to have this. I also have a 97 pearl white. Same issues.
Old Jan 31, 2007 | 08:00 AM
Always Overcharged's Avatar
Default Dont cause any sparks or you wont need to worry about the repair-I dont think they have
A8's in heaven
Old Jan 31, 2007 | 08:55 AM
Default Re: Dont cause any sparks or you wont need to worry about the repair-I dont think they have
Is it valid to be worried about disconnecting the battery cable? I am a novice at best on working on these cars, I really don't want to goof up the computer, especially on the wifes car. Thanks for the input guys.
Old Jan 31, 2007 | 12:13 PM
Default Shouldn't do anything to the computer. I think there are fuses and such to protect them even if
it did.
Old Jan 31, 2007 | 08:22 PM
Default definitely dissconnect but get your radio code first-all the answers re
resetting windows etc will be answered by the forum on request
 Pouria Savadkouei
 Michael S. Palmer
Angelo Pappas
May 1, 2009 09:33 AM
Small Town Terrorist
Audi Original "S" Cars
Feb 6, 2005 01:43 PM
Zzak
Jan 30, 2004 08:55 AM
Aussieguy
Jan 11, 2003 10:41 PM
Audi Dudey
Sep 18, 2000 07:58 PM
