Oil Cooler repair
Attempting to apply the article by Scot Danrich about servicing Audi oil coolers to a friend's 1997 Audi A8 Quattro. The only symptoms the car showed were a dropping oil level and oil showing up in the coolant. It was diagnosed by the Audi dealer as a blown head gasket, with an estimate of many thousands of dollars to repair.
However I gave the car a compression test and compression was good on all cylinders. Never having seen a head gasket blow only between an oil gallery and the water jacket, without blowing to a cylinder, I had doubts about the dealer diagnosis and began looking elsewhere. Could be a cracked head or block, but once I discovered there was an oil cooler that has both oil and water connected to it, that became the next logical culprit to check out.
I started doing the procedure outlined, but am now stuck. My problem is Scot's article seems to be based on having a lot of other stuff removed from the front of the engine, the radiator, probably the subframe, etc. I only removed what it said to, including the air filter box and the alternator. I have the oil cooler completely unbolted and free of the block, but can't get it out of the engine compartment. It's trapped between the exhaust manifold and a large tubular frame element that supports the front bumper. I can wiggle the cooler around and rotate it slightly, but can't get it out.
The article mentions unbolting one of the engine mounts and jacking up the engine on that side to provide better access to that area. I did that, but jacking on the engine just raised the entire car, even with that engine mount disconnected. There appear to be more mount points, specifically it looks like there's one that attaches to the frame in the region below the right headlight. So it looks like there may be a one or more steps missing in the procedure, and more things that need to be removed.
If anyone has experience with removing and replacing the cooler with the engine, radiator, fans, etc remaining installed in the car, please help.
PS: I struggled for about an hour to drain the radiator using the petcock -- with the tranny cooler lines going right in front of the valve, couldn't get a straight shot at all with several different screwdrivers, and the valve was very tight too -- only succeeded in damaging the slot in the blue plastic. Finally just gave up and pulled the lower radiator hose, making quite a mess.
The back bolt that is high on the oil cooler is a real bear. You can barely see it, from up top, with a very carefully placed inspection mirror. I was able to remove it with two extensions and a u-joint, and the appropriate Torx bit and a rachet handle.
Also, I did not have to lift the engine in the sub-frame, to remove mine.
ASSuming much of these 'gems' are same for '01 //S8?
Hmmm, sounds ahem fun - "can't wait". Hoping the culprit will be obvious with bumper / alternator removal. Bumper sounds easy as me C4; any alternator secret handshakes to keep in mind?
Unrealated-
Anyone got a spare belly pan layin around? Again ASSuming they're all one in same '97-'03 or would that be a dangerous ASSumption? PO's "wife" (hey it's always the wife right) apparently er disposed of it - evidence the slight tear in the underbumper black skin from being kerbed and backed out after. YOINK!
After getting the cooler off, found the plastic pipe was broken just like the one shown in the article. The O-ring and the end of the pipe had to be fished out of the block, and the O-ring was warped like a potato chip! I can see how this would allow oil to leak out onto the ground, but haven't yet figured out how this would allow oil into the coolant. May have more than one problem?
With the cooler out, I'll now try to find someplace that can pressure test it somehow. I'd think rubber stoppers that fit the coolant passages, one with a compressed air fitting on it, should do the trick.
There's a housing on the inside, that I assume encloses some kind of heat exchanger. It's held on with about a dozen Torx screws. Should I take it apart? I didn't get the gaskets for that.
The O-rings lasted less than 110,000 miles on my car, so I'm changing them every time I change the timing belt from now on.
Tom
