trouble with the "REST" feature
If you disconnect it, the pump will never run again, and the noise will go away.
It has a purple color code piece.
I'm pretty sure it has a low voltage shutoff because pulling up on the switch for an already-closed window will sometimes shut mine off.
If that's why yours is shutting off early, it could be because of low battery charge, a tired battery, or a less than perfect power or ground connection on the way to the HVAC controller.
Tom
Tom
The pump runs when the car is running, and it makes a very annoying gear-motor whine/grindy sound.
Once again, the pump runs when it's not supposed to, it does not fail.
Tom
