car not starting
Old Feb 5, 2007 | 08:25 AM
Fabio's A8's Avatar
Member
Default car not starting
My '97 a8 quattro is not starting in this bitterly cold weather we're getting in Toronto. The engine is not even turning over. I just heart the noise from the starter. Any ideas? Is there any kind of cold start device like block heater on these cars or something else that could help me out?
Old Feb 5, 2007 | 08:53 AM
CalG's Avatar
Junior Member
Default Re: car not starting
Warm the battery!
I like to put a small trickle charger on.
Less than 1 amp, over night when it's cold.
If you are getting "some response from the starter, but no engine turn over, it's POWER you need.
A warm battery has lots more to give than a cold one.
On the A6, I have installed a lower radiator hose heater. Thermo-siphon carries the heat up into the engine block. No help to the battery, except the engine starts readily. The best part?? Warm air at the heat and defrost moments after the engine is started! A very good thing!
CalG
Old Feb 5, 2007 | 11:43 AM
Always Overcharged's Avatar
I know an exotic car collector that uses old waterbed heaters under the cars at night
Old Feb 5, 2007 | 11:48 AM
sandwich's Avatar
just stumbled on this thread...
check your coolant. Sounds dumb, but my coupe wouldn't start in 3` weather because the PO had too much water in the mix. Easy way to kill your engine. A jump might cure it if that's not it, or a new battery.
Old Feb 5, 2007 | 01:45 PM
CalG's Avatar
Junior Member
Default Re: car not starting due to anti freeze
Anti freeze concentration?
Are you saying that the coolant has thickened or frozen such to inhibit the turning of some engine part? What? The water pump?
I fail to see any connection between an engine not turning over and the state of the cooling water in the jacket, or anywhere else.
Help me with the logic here.
CalG
Old Feb 5, 2007 | 01:50 PM
CalG's Avatar
Junior Member
Default Re: I know an exotic car collector that uses old waterbed heaters under the cars at night
Warms the air, dries it out and helps keep the cars from rusting
CalG
Old Feb 5, 2007 | 02:22 PM
Zaphod A8's Avatar
Junior Member
Wouldn't heating the coolant in the hose just dump the heat out the radiator?
Old Feb 5, 2007 | 05:23 PM
tozoM8's Avatar
Tech Guru
No, it discharges it's heat when you start the car. Very popular in northern Europe.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 5, 2007 | 09:41 PM
he leaves them under the sump to prevent cold starting
Old Feb 6, 2007 | 04:39 AM
pkrasusky's Avatar
Default Def. don't want my //S8 to rust 8-)...
...also why it's salt encapsulated now.
Good idea for der TR3 tho. No, wait a minute - they're ***well equipped*** with "factory undercoating" aka the chassis is well ahem lubed.
What's an old waterbed heater run? Suck up much power? I did end up with some rockerbubble on me now what 12 yr. old 'resto'. GUESS that could have been prevented by parking over more than er the chassis-length scattered old cardboard boxes aka drip pans. But that'd make 'sense' (overrated)...
