Tranny limp mode update
Old Feb 5, 2007 | 05:11 PM
pkirby's Avatar
Default Tranny limp mode update
Last week I posted that my '02 S8 (61K mileage) went into limp mode and I had a few funny electronic bugs. After a week of driving (appprox 15 miles a day) the car returned to normal. Tonight as I was backing into the garage, the tranny went into limp mode again. I was going to drop it at the dealer for investigation (car is certified for another year) but will hold off as I can't get to the dealer this week. I would guess that the problem is most likely the F125 switch as pointed out in the posting responses. I'm hoping to document with the dealer and AOA in case this problem continues past certified warranty coverage so that I can build a case. I'll keep you posted.
BTW what type of brake fluid does the S8 take ? I need to get the fluid changed out.
Old Feb 5, 2007 | 05:29 PM
TerminA8r's Avatar
Default I use ATE Gold and Blue fluid, they are the same fluid, but different colors.
<center><img src="http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/brakebleed1.JPG"></center><p><ul><li><a href="http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/brakebleed.html">Brake Bleeding By Paul Waterloo</a></li></ul>
Old Feb 5, 2007 | 05:43 PM
Angus Beef's Avatar
Default mine did that when the VB wiring harness was dirty
sounds like you need to clean that plug. also, put some dielectric grease on it to keep dirt/water out in the future
Old Feb 5, 2007 | 06:35 PM
ryoung's Avatar
Elder Member
Default ATE Gold/ Blue brake fuid is highly rated.
I use Castrol SRF, but you can use any DOT4 or DOT 5.1 brake fluid. Absolutely DO NOT use DOT 5; this is a silicone brake fluid, and it's not compatible with the ABS system.
The owner's manual recommends bleeding brakes every other year. IMHO, you'll be pleased with the firmer pedal that usually results from annual bleeding.<ul><li><a href="http://www.evilplastic.com/bfluid.htm">Brake Fuild Comparison</a></li></ul>
The S
Audi allroad
Dec 17, 2006 08:55 AM
Phantom RS
Rocky Mountain Discussion
Oct 6, 2006 08:21 AM
pete423
Jan 28, 2006 06:37 AM
Karpedmman
Oct 15, 2003 07:23 PM
BigThistle
Sep 10, 2003 01:24 PM
