Can I drive my car without the driveline installed?
Old Feb 8, 2007 | 06:38 AM
cherbert's Avatar
Default Can I drive my car without the driveline installed?
Or will the diffs freak out? I need my driveline serviced, but I also need basic transportation.
Old Feb 8, 2007 | 07:19 AM
A8CT's Avatar
are you asking if you can drive the car w/o some of the driveline installed?
Old Feb 8, 2007 | 07:20 AM
A8CT's Avatar
Default Re: are you asking if you can drive the car w/o some of the driveline installed?
are you getting an axle or driveshaft repaired?
Bob
Old Feb 8, 2007 | 08:37 AM
CalG's Avatar
Junior Member
Default Hmm ...can they???
Do a check on Tor-sen systems. They have some interesting characteristics, and "drive open" may be permitted.
They are designed to shunt the drive power to the end with the Most traction. a disconnected drive shaft would represent the least amount of resistance.
There may be a "slight complication" of output speed multiplication however. Differentials will do that.
I wouldn't try it.
CalG
Old Feb 8, 2007 | 09:13 AM
cherbert's Avatar
driveshaft
Old Feb 8, 2007 | 09:32 AM
skiracer's Avatar
Default I would NOT drive your Quattro without the rear driveshaft installed.
The torsen would likely tear itself apart, or some other nasty result.
Old Feb 8, 2007 | 09:55 AM
Angus Beef's Avatar
it wont move. the torsen needs some load on it to function.
Old Feb 8, 2007 | 12:47 PM
Always Overcharged's Avatar
bad thinking batman
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 8, 2007 | 05:57 PM
icsamerica's Avatar
Default consider this...
You could get a junkyard unit, take a chance, it might be good enough to use for some time. If not have it rebuilt then install it. Or, bite the bullet and get a new unit from the dealer. You're driving a fine car so it's OK to use fine parts.
Old Feb 8, 2007 | 06:16 PM
tozoM8's Avatar
Tech Guru
^^^^ He is right.^^^^
WECoyote-SuperGenius
NY / NJ / CT Discussion
14
Jan 30, 2008 04:57 PM
TTpilot
Mar 29, 2005 05:15 PM
