1997 purchase? opinions please...
Having it inspected and plan to use the audi pages http://www.audipages.com/usedA8.html inspection sheet. Any thoughts?
Current ride is a 01 Olds Aurora w/4.0 and my wife's car is an A6 2.8.
So far, I've had 4 disappointments:
1) I replaced a high beam bulb and still couldn't get it to work. Got some help that it might be electrical issue, but still yet need some tool (VAG-COM) to iron that out.
2) I experience some shaking/noise from the front whenever I max out my steering radius. Cause was likely to be CV boot or axle. I replaced both front outer CV boot as 2 different mechanic said they cracked open and it would cause damage to axle and more if I don't replace them soon. Did that at a mechanic shop for $600 and I feel almost no difference other than believeing I did the right thing by preventing "the big repair."
3) Previous owner claims there might be keyless entry lost by other previous owners. Anyway, I called Audi dealers to find out if mines has one; they couldn't check for me! I still don't buy the idea that they couldn't check if my A8Q has one by my VIN. Plus, I seriously thought that all A8Q has keyless entry.
4) I must use my key to open back trunk. The button located in door jam doesn't work. Or maybe there's some sort of safety switch in the trunk?!
Anyway, I just hope that anybody consider owning an Audi, especially the A8 would consider some thousands of $$ overhead after purchasing. e.g. I owned it since last summer, and spent just under $2k on parts/minor upgrade/maintenance.
All in all, if you own one, you've gotta enjoy her as much as you can! I certainly do
--- New transmission service (new fluid & filter)
--- New brake pads (both front & rear)
--- Replaced inner & outer tie rods (front wheels)
--- Replaced oil pan gasket
--- Upgraded Eibach sport springs
--- Installed DVD system in center console
--- might have more work done not recorded here...
PREVIOUS OWNER (2005-2006):
--- New misc. cabin light bulbs
--- New windshield washer jets
--- Replaced front control arm
--- Replaced drive shaft seal
--- Replaced exhaust seals
--- Replaced spark plugs
ME (2006-Present):
--- 4 wheel alignment
--- New tires
--- New chrome license plate holder
--- New air filter
--- New headlights (all bulbs)
--- New windshield wiper blade
--- New brake fluid (flush & fill)
--- New Front outer CV Boot
--- New lug nuts for front control arm
--- Re-adjust front control arm tension
2)I have that noise, but only at very low speed at full lock with throttle.
3)You need two keys and a remote, then you can program it to your car.
4) If the glove compartment is locked or the key slot on the trunk is vertical, the button on the door pillar doesn't work.
2) i'll just ignore that noise as it's less frequently heard than before.
3) do i need vag-com to program it or was the programming capability built-in to any of the flip-key-keyless entry available on eBay?
4) the glove box was locked... i'm much happier now. thanks for the info!
