Valve Body parts differences
Now I'm trying to get the expert to illuminate the differences.
Regards
CalG
Transmission m.y 1997 DTE 01L 300 041G ZF # 1058 020 009
Transmission m.y 1999 EDG 01L 300 042A ZF # 1058 020 014
Valve body part changes:
Position Number ZF Part Number Description Comments
27.010- 1058 327 086 Duct Plate ALL reference
27.074- 1060 227 019 Valve ADDED Starting 014
27.110- 1058 327 032 Intermediate Sheet DTE 009
1058 327 032 EDG 014
27.180- 1058 327 035 Intermediate Sheet DTE 009
1058 327 066 EDG 014
50.128- 0732 041 423 Compression Spring DTE 009 Modulating Valve
0732 042 123 EDG 014
50.030- 0732 041 547 Compression Spring DTE 009 Damper Piston
0732 042 736 EDG 014 "A" clutch Accumulator
51.270- 0501 210 061 Pressure Regulator DTE 009 EDS Solenoid (4pc)
0501 208 542 EDG 014 Starting 014
Kit 0501 208 542
51.010- 1058 327 063 Valve Housing ALL reference
55.010- 1058 327 059 Valve Housing DTE 009 *********
1058 327 068 Upper EDG 014 Slot not present
55.030- 0732 041 894 Compression Spring DTE 009 Converter clutch apply*********
0732 042 034 EDG 014
55.140- 1019 327 012 Piston EDG 014 KV-E
1055 327 059 DTE 009 Clutch Valve "E"
55.1500- 0732 041 462 Spring EDG 014 Kit with above Piston
0732 041 667 DTE 009
27.0440- 0501 314 645 Rubber Part Early VB Kit
1068 227 039 Piston Late VB
