Transmission adaption via Vag-Com "warm boot?"
Old Feb 10, 2007 | 08:53 AM
CalG's Avatar
Junior Member
Default Transmission adaption via Vag-Com "warm boot?"
The Low air flow DTE kicked on the Czec Engine light again last night, so I discoverd once the VAG-Com was hooked up. No big event, just cleared and all is well, Hoses were pulled this morning, and they are dry and clean hmmm..
But while I was hooked in with the VAG-COM, I took a look at adaptation possibilities with the transmissoin (02)
There appears to be only a single active adaption code 000and that resets to factory defaults. At least that is what the VAG-COM disply indicates.
Figuring noting to loose, I activated the adaptation. Nothing fentured, nothing gained.
When looking for information regarding transmission adaptation in the ebahn service literature, there is no mention of this adaptation resetting discoverd in the topics displayed via the search function.
Would this procedure be akin to a "warm boot" as opposed to a "cold boot" that is achieved by disconnecting the battery power for 15 minutes,
perhaps some have come across a reference to this elsewhere.
Regards
CalG
Old Feb 10, 2007 | 11:41 AM
Always Overcharged's Avatar
Default for 01l1 and 01l3 trans
Resetting adaption values of gearbox control unit (basic setting)
Notes:
? The adaption values of the gearbox control unit should be reset after performing repair work on the valve chest (e.g. after renewing solenoids), renewing the valve chest, the torque converter or the gearbox.
Thus the adaption values for the standard operating mode of the gearbox control unit will be learned more quickly when restarting.
? The adaption values of the gearbox control unit will be reset if:
? The multi-pin connection is disconnected from the gearbox control unit for at least 15 minutes=>Page 01-23
? The battery is disconnected for at least 15 minutes
=> Electrical system; Repair group 27
Old Feb 10, 2007 | 12:48 PM
CalG's Avatar
Junior Member
Default why no mention
01L Tranz ABZ series vehicle
Yes, that is what the service book says. I wonder why no mention of the VAG tool reset capability.
Regards
CalG
Old Feb 10, 2007 | 05:42 PM
Zere are zings zhey dont vant you to know Herr Calg
rwester19
VAG-COM Discussion
Nov 4, 2009 06:57 PM
undrway
Sep 21, 2001 06:23 AM
mfjp
Jun 11, 2001 12:44 PM
LFS4
May 4, 2001 12:09 PM
