Timing belt kits: price differences - is it worth it?
Old Feb 10, 2007 | 09:44 AM
testarossaguy's Avatar
Default Timing belt kits: price differences - is it worth it?
I've already ordered the Blau kit for my 2001 A8L at a cost of $589 for the kit. Just roaming around and checked on importec's website and they show a price of $166. Is the Blau kit truly worth that much of a difference?
Old Feb 10, 2007 | 10:25 AM
Silver Streakin''s Avatar
Member
I'd contact: WorldImpex.com, PureMS.com, ECStuning.com
Old Feb 10, 2007 | 11:20 AM
JimR's Avatar
AudiWorld Uber User
25 Year Member
I'd take a hard look at what a $166 kit includes.
Old Feb 10, 2007 | 11:30 AM
Angus Beef's Avatar
it cant be more than just the belt....
Old Feb 10, 2007 | 11:41 AM
Default Re: it cant be more than just the belt....
Here's what importec shows in their kit:
Kit Includes: 1) 078 109 119C Timing Belt 1) 077 109 485C Tensioning Lever 1) 077 109 244E Relay Roller 1) 077 109 244C Relay Roller Continental Belt w/GMB Components
Old Feb 10, 2007 | 11:48 AM
ECS Tuning shows their timing belt kit at $209. Is component quaility the main cause of price differences? If not, and each supplier's kit is similar then I'm cancelling my order with Blau.
Old Feb 10, 2007 | 12:00 PM
Angus Beef's Avatar
Default blau also gives you the waterpump, thermostat, crank seals, coolant, etc
all stuff you should be replacing...
Old Feb 11, 2007 | 06:23 AM
gtrucinski's Avatar
Default What is your motor worth?
I know a lot of people use Blau...but for something like this AUDI PARTS ONLY.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 11, 2007 | 06:39 AM
gondar's Avatar
Member
Default Audi does not manufacture timing parts
The issue is, are the parts from parts houses of the same quality or exactly the the same as from Audi's OE suppliers? I doubt, for example, that Conti makes more than one quality timing belt for an A8. Ditto rollers; FEBI? The water pump I don't know about. Or the tensioner. I wish someone would tell me because I will need to do 40V TB job pretty soon. Does somebody make a failsafe thermostat, i.e., one that defaults to the open mode?
My assumption is that there are a lot more substandard far eastern and ex Warssw pact parts floating around for mass market cars than for semi-exotics like A8s. You would tool up and distribute what you could sell the most of if you were in the parts biz.
Old Feb 11, 2007 | 11:03 AM
JimR's Avatar
AudiWorld Uber User
25 Year Member
Default There are definitely some Chinese control arm kits around.
Don't forget, there's a Chinese Audi factory that makes an A6 version, primarily for home-market high-rollers. It's a limo, there.
