Issue with setting alarm manually while pass. rear door is open... (97 A8q 4.2)
Old Feb 10, 2007 | 04:35 PM
rAudiA8's Avatar
Default Issue with setting alarm manually while pass. rear door is open... (97 A8q 4.2)
Ok, so I don't have a programable key for my car so if I'm getting groceries out of the rear of the car I'll open the drivers side back door, put the key in the drivers door and turn to the right to lock the car and set the alarm... but with the rear door open, the alarm does not set until the door is closed (this helps when my hands are full so I can just "hip" the rear door closed, which then "sets" the alarm...). So here's my issue... this technique only works if the drivers rear door is open... if the passenger rear door is open while I try this technique, the alarm starts going off after a few seconds... any idas or suggestions as to why? this is a weird one...
Old Feb 10, 2007 | 04:43 PM
Angus Beef's Avatar
door open switch on pass side busted. motion sensor setting alarm off.
Old Feb 11, 2007 | 07:48 AM
PaulW's Avatar
Default Agreed
You can verify this by opening a rear door with the car running....passenger door won't show open on the dash because the switch is gone.
Both of mine have been gone for some time.
Old Feb 11, 2007 | 03:14 PM
rAudiA8's Avatar
Thanks a lot guys, will check out that prognosis and let you all know...
Stoneybroke
A6 (C7 Platform) Discussion
13
Sep 15, 2014 04:38 AM
djtnut
Audi allroad
Apr 23, 2012 10:15 AM
Stoney
Jan 7, 2007 12:57 PM
Stoney
VAG-COM Discussion
Jul 23, 2006 08:43 AM
RGa6
Audi 100 / A6 (C4 Platform)
Apr 27, 2006 11:20 AM
