My timing belt job continues....FIRED HER UP...ran nice and quiet !!
Anything around the wheel area? I know you removed the leveling sensor for the headlight.
A scanner will p/u the CEL code, I don't know if a standard OBD unit will read the ABS/ESP code though.
Bob
Engine Code 17521
ABS Code 18265
Transmission Code 18265
I cleared the engine code and the little light went out. But I could not clear the ABS or AT code of 18265. I also couldn't reference it as to what it means. What is this code?
I will try go over every thing very carefully tonight, looking for bad hoses and loose connections. I have not yet hooked up the air tube that goes between the air filter box and the throttle body...could this intake of unfiltered air cause this problem? Is the air filter box have a sensor saying "no air flow" and yet the engine is running say "I have air"?
The one you posted just relates to an oxygen sensors ahead of one of the catalysts, and is not caused by the disconnected air hose. Both pre-cat oxygen sensors are probably ready to be replaced at this mileage and, if they're like mine were, will continue to log such codes intermittently until changed.
If you're going to continue to work on the car, you'll really benefit from a Bentley service manual CD-ROM or web subsciption.
Tom
