homelink project
You can verify this by noticing that your vanity lights on the mirror don't work when the visor is unclipped and positioned to block the sun from your side window (unclipping and moving it opens the circuit). Also, as you start to rotate the visor up into its storage position, the vanity lights will turn off.
With this info, you should be able to figure out where to wire the homelink. I just ran a new wire from the clip, under the headliner and down by the hinge so that my homelink works no matter what position the visor is in.
Good luck.
<ul><li><a href="https://forums.audiworld.com/a8/msgs/132986.phtml">https://forums.audiworld.com/a8/msgs/132986.phtml</a</li></ul>
