Driveshaft clicking - all who fixed it, cv joints at end freezing or the center bearing going?
Old Feb 25, 2007 | 09:39 PM
wisconsin_quat's Avatar
Default Driveshaft clicking - all who fixed it, cv joints at end freezing or the center bearing going?
My driveshaft is clicking with every rotation, usually in reverse but also in drive when i give it hard.
I heard blau can rebuild the center bearing for $60, and they are only about an hour away from me. (I would pull out and bring the shaft there)
Just want to explore my options. Right now I'm leaning towards a used shaft for around $150ish
Old Feb 26, 2007 | 08:31 AM
Dan McBoost's Avatar
rebuild it. been there done that.
Old Feb 27, 2007 | 07:03 AM
ex-a8drifter's Avatar
Default Driveshaft for 150? I replaced mine with rebuild at around 500 + core. A8CT has replaced as well.
Do you mean fron CVs in the half shafts? I don't believe that the center bearing goes out. Its usually the CV joint right after the output shaft from the transmission that goes. It made a really loud squirrly metallic noise for me and a few others.
Old Feb 27, 2007 | 02:35 PM
Default my noise is coming from right under the car - right in front of the differential
i ended up buying a used driveshaft for around $100 . I'll take my chances. I think i'll find that the center bearing is shot when i take it apart.
shadowgates22
Feb 4, 2011 10:56 PM
hgoodman
Jan 19, 2009 02:00 PM
A8CT
Feb 15, 2006 03:49 AM
Audi[]Viruz
Apr 30, 2005 03:21 PM
SteveAngry
Sep 7, 2003 10:37 PM
