FWD Steering
Old Mar 2, 2000 | 09:28 PM
SLChiu's Avatar
New Member
Default FWD Steering
Hi,
I have been following this Forum since Sept. 1999 when I decided to buy a
TT for my new car. I should say that I have enjoyed my TT and this Forum
since then.
Now my question is about the steering of FWD TT. When I first got my
car, the steering is very tight and precise. But I noticed that at about 5000 miles
it started to have free play. I took it back to the Audi dealer here at San Jose.
A rep took a test drive with me and told me that this is normal. He said that
the steering will start having free play at about 5000 miles. But I will get the
same tight steering back once the recall modification is done. Now my car has
12000 miles on it and the steering is getting worse. My question to all TT
owners is "Are you experiencing the same thing?" and "Will the recall
modification fix it?"
Thanks.
Chiu
Old Mar 2, 2000 | 11:24 PM
RogDog's Avatar
Member
Could it be related to tire wear? I'm guessing.
Old Mar 3, 2000 | 02:01 AM
Marius's Avatar
Junior Member
There should not be noticeable free play at all. Have a mechanic check it.
Old Mar 3, 2000 | 02:55 AM
OTOF's Avatar
Elder Member
Have 6,800 miles on my FWD. No play in the steering.
Old Mar 3, 2000 | 04:40 AM
Joe's Avatar
Joe
Banned
Default My TTQ and the steering
I included complaints about a dead-spot in the steering when I brought my TTQ for its 5K service a few weeks ago.
They found that the front end was out of alignment. Toe, which is supposed to be between -5 and -9 degrees, was actually +2/+3. So I would first start with an alignment. It helped my car dramatically, although I still think the steering lacks a certain sharpness.
Secondly, I would totally ignore the comments made by the rep to whom you demonstrated the issue. The steering will start having some free play at 5K miles? That is TOTAL BULLS@IT! If that were true, it would steer like a tractor by 25K.
You shouldn't need the recall to expect precise steering with no dead spot. I would suggest having them check your alignment.
Let us know how it goes!
--Joe
Old Mar 3, 2000 | 05:11 AM
Kurt's Avatar
Junior Member
Default 13500 miles on my FWD
No free play on my steering. I think your dealer has free play in the brain.
Old Mar 3, 2000 | 06:48 AM
Larrytt's Avatar
Elder Member
9000 miles on my TTQ and the steering is tight!
Old Mar 3, 2000 | 04:41 PM
DuTTCH's Avatar
Default Re: Don't turn the wheel when NOT moving
This is something a lot of people do, since it has power steering they will try to turn the steeringwheel while the car is at rest, this will work (since it's powersteering), BUT it will loosen up your steeringmechanism.. So, always make sure you move when you turn the wheel..
I guess having driven an Audi 80 (no power steering) thought me this ;-)
 Pouria Savadkouei
 Michael S. Palmer
guy14
Sep 10, 2018 05:07 AM
JONATHANCLARK
TT (Mk2) Discussion
Sep 26, 2017 11:48 AM
dale55
Feb 8, 2010 09:17 AM
QuattroSV
May 29, 2009 07:27 AM
vDubr
TT (Mk2) Discussion
Nov 23, 2008 06:22 PM
