Borla Exhaust $20 Upgrade...
LarryTT turned my on to it, and I think a couple of the other guys have it too..
Believe it or not, there is a difference.
The standard U-bolt clamp that comes with the Borla "leaks", even when TIGHT.
The EasySeal (basically a 3-4" strip of Stainless Steel) completely seals the gap between the cat-back pipe and the muffler section.
Sure enough, when I went to remove the old, standard clamp, I found carbon deposits running back TOWARDS the catalytic converter...
The junction is now airtight.
Sounds better, feels better.
Well worth $20 if you can find them...
Thanks, LarryTT..!!!!
ScouTT
'00 TTQ 180 RavenBlack: Garrett Stage2 / H&R Springs / K&N / Borla / V1 / LLTek mats / LLumar Tint
Desert Green TTQ, H&R Springs, BBS wheels, Borla<ul><li><a href="http://www.jcwhitney.com/product.jhtml?CATID=14701">http://www.jcwhitney.com/product.jhtml?CATID=14701</a</li></ul>
(Then again, I feel like a bigger idiot for buying into the PALM IPO at $110...)
The Borla on the Quatro comes in two pieces..
The fron section clamps with the standard clamp. The rear section (muffler) comes with the U-bolt, which for $7 YOU MUST REPLACE with this clamp from JC Whitney..
Don't ask questions..
Just do it and thank me next week...
ScouTT
http://www.jcwhitney.com/item.jhtml?ITEMID=2150
(You want the 2.25" diameter for the rear junction.)
(Maybe who-ever installed yours used one of these..? Mine came with a U-shaped bolt, two nuts, and a curved doohickie...
