Power vs. Manual top
Old May 5, 2000 | 06:47 AM
Ashma's Avatar
New Member
Default Power vs. Manual top
Can the manual top be raised while inside the roadster (i.e. grab and pull over one's head) or is it too heavy to do so? Also, how much weight does the power top add to the car? I am purchasing the 180 fwd version and can't decide on whether to go power or not.
Old May 5, 2000 | 07:01 AM
encierro's Avatar
Default Re: Power vs. Manual top
I have a manual top. I don't mind it at all. I can lift it up from inside the car. Actually I can get it up and down faster than the automatic top. The hardest part about the top is putting the cover on, and unfortunately you have to do that for both the automatic and manuel. ANd that you have to get outside the car for. Anyway I really had no choice in the matter but I am happy with the manuel. No complaints here, and I don't have to worry about another thing that could break down.
Old May 5, 2000 | 07:20 AM
TTR Kevin's Avatar
New Member
I agree entirely
Old May 5, 2000 | 07:30 AM
Parshall's Avatar
New Member
Default Go manual for 180
I truly believe the only reason they put the power top on the 225 is to add weight to the rear to improve handling. I can manually put down the power top while sitting in the drivers seat.
All the mags say the option weighs 150lbs.
Old May 5, 2000 | 09:06 AM
Investment Man's Avatar
New Member
I have the 225 TTQR so I have the automatic top.
There is really no need for the electric top. You have to apply a good deal of effort to crank the release handle anyway.
I say save the dollars and the weight if you are getting a 180.
Old May 5, 2000 | 10:51 AM
Ashma's Avatar
New Member
Thanks guys - called my dealer and changed to the manual top instead
Old May 5, 2000 | 12:37 PM
ChuckH's Avatar
Member
Default Actually, I think they offered it for us lazy Americans! :-)
<p>Charles
2000 Nissan Xterra SE V6 4x4
'98 A4 2.8 Q-Tip (employer owned)
Old May 5, 2000 | 12:44 PM
TTeleven's Avatar
Power and manual version both require cover to be removed manually from outside car B4 top goes up
 Pouria Savadkouei
 Michael S. Palmer
A4Driver
A4 (B8 Platform) Discussion
10
May 2, 2009 11:23 PM
guggy1973
Oct 30, 2007 11:33 AM
Youreviltwin YFF
A4 (B7 Platform) Discussion
Nov 13, 2006 09:20 AM
COT51E-ukcab
Nov 23, 2002 12:08 PM
A4TURBO2 // TMK
11
Apr 24, 2001 11:00 PM
