Unintended service: turbo bog
Anyone else have this problem? More later.<p>Ivan
<i>Jacksonville, Florida<i>
<img SRC="http://www.geocities.com/y2ktturbo/tinytt.jpg" BORDER=0>
"Zorro" 2000MY, 180hp, Fronttrak, Silver/Ebony
K&N, Garmin EMap GPS, Audi "mask", Cobra R/D
I've only had mine a month, so I wasn't sure if it was me, or it's still settling in, or ?<p><a href="http://registry.audiworld.com/audi/registry/details.asp?car=4626"><img src="http://homepage.mac.com/galaxian/.Pictures/mmttsig.jpg" alt="Click here for my registry entry." border=0></a>
2000 Aviator Gray TTQ
I, of course, expect the dealer to find nothing wrong.
And I have a very good dealer.<p>Ivan<i>Jacksonville, Florida<i>
I still need to learn how to drive right. Moving out on first with consistent power output is not happening since my clutch - throttle coordination is off.
Any suggestions?
later
Kalki
If I try and pull away quickly, and I don't quite give it enough gas, then it bogs down until the revs get up into the boost range.
In the Impreza the power deficiency is very pronounced because of the massive difference in power and torque between the boost assisted engine and the normally aspirated engine. To give you a clue what I mean, the same 2.0 litre engine without any turbo only puts out about 112bhp. The turbo engine puts out 276bhp.
So, for those 1-2 secs while you are under no boost, the engine behaves like it only has 112bhp, which means it bogs down big time compared to what you are used to.
Interestingly, when I test drove the 225Q, I found that this wasn't a big problem, as Audi appear to have done a lot of work to ensure that off turbo power delivery is very well matched to on-turbo power. The transition between the two is almost seamless. This is maybe not possible with an unmodified 180(Q).
I'd be insterested to hear if any of the guys with chipped 180s have the same problems with bogging down.
<a HREF="http://larrytt.tripod.com">Larry's TTQ WebSite
