Help with "off gas" or plasticizer removal please
Old May 7, 2000 | 04:44 PM
Lloyd of the Rings's Avatar
Default Help with "off gas" or plasticizer removal please
Glass cleaners, I've tried them all, including now Zaino Z-12. I just can't shift that film you get on the inside of the windshield. All Z-12 does is kind of smear the film around. It looks awful in low, direct sunlight.
Anyone have any suggestions?<p>ChrisTTopher Lloyd
2000 Silver/Ebony 180TTQ
All packages except phone
Old May 7, 2000 | 05:00 PM
Jurgen's Avatar
Default Z12 worked great for removing heavy film build up.
I use Armor All Auto Glass Cleaner to clean the windows, when they are not too dirty. I get the best results while using paper kitchen towels with the cleaner.
Hope this helps<p><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/jk.jpg" border="0" alt=" "></a>
Old May 7, 2000 | 05:11 PM
Default Do you apply the cleaner to the glass, or to the towels?
Old May 7, 2000 | 05:39 PM
Jurgen's Avatar
Default I spray the cleaner to the glass and use a lot of paper towels.
Old May 7, 2000 | 05:42 PM
Default Thanks!
Old May 7, 2000 | 07:05 PM
Warren Wang's Avatar
Default I'm cheap...
Go buy a 70 cent bottle of 90% isopropyl alcohol. Put about half of it in a bottle, put a drop of Dawn, and a few ounces of water. Use liberally to remove any window film.
Also, it really helps if you start out with a somewhat moist cotton terry towel. Every other kind of towel (paper, non-terry, etc) that I've tried haven't had nearly as good of results.
Warren
Old May 7, 2000 | 07:37 PM
Default Good advice, I'll try that too
Old May 7, 2000 | 10:13 PM
BrunoTT's Avatar
New Member
My detail shop uses newspaper to wipe off the spray...thought they were crazy but it works GREATT!!
 Pouria Savadkouei
 Michael S. Palmer
Old May 8, 2000 | 03:02 AM
OTOF's Avatar
Elder Member
Default LOL, that's my Mom's window-cleaning trick!
<p>
Old May 8, 2000 | 11:19 AM
phred's Avatar
Senior Member
Default Here's my secret
Almost anything works (Windex, Invisible Glass, Glass Wax, etc.), you just have to use it 2 or 3 times depending on the thickness of the haze.
Afterwards, you might try using your slightly damp real or synthetic chamois to get the last bit of haze. Newspaper is great but it shreds in your hand and all over the dash. I like to use moving paper, which is unprinted newspaper.
Lloyd of the Rings
May 16, 2000 11:03 AM
TT in TX guy
May 6, 2000 02:33 PM
krfTTwrk
May 1, 2000 10:19 PM
Lloyd of the Rings
9
Apr 28, 2000 11:58 AM
