Want Decib. readings for stock, forge/miltek resonated, non resonated, and UUC>>
I'd like to get some Db readings of my exhaust and compare them.... that way I know which exhaust I want when I get my TT
As long as its not louder than what i have now.Another question for those who did the actual Db readings.... Where did you get your Db meter?? Or better yet, where could I get one?
thanks!
like that
nice chart though!
I'll have to test mine and see. A question. I'm assuming the 3000rpm and the 5000rpm were just free reving in nuetral??
How did you get the 2000rpm under load. Just curious so I can repeat your test as close as possible. Did you guys do any from inside?
OEM OEM No Resonator No Resonator Resonator Resonator UUC UUC
90degrees 5feet 90degrees 5feet 90degrees 5feet 90degrees 5feet
Idle 58.6 61.4 67.1 71.9 67.1 68.2 69.9 73.9
3,000RPM 68.3 69.9 79.5 80.6 72.6 73.2 79.6 82.1
2,000RPM Loaded 68.4 70.5 73.9 78.5 72 75.1 82.9 84.9
5,000RPM 81.7 81.7 85.1 85.1 79.8 79.8 87.2 87.2
They had the meter right by the drivers left ear, drivers window down, pass window up.
Stock mustang
Idle 65Db
1500 68Db
3000 71Db
Mustang with bassani headers, X pipe with cats, mufflers and tailpipes, same as before, inside car, drivers window down, pass window up, mic by drivers left ear.
Idle 67Db
1500 70Db
3000 73Db
Then they tested the bassani exhausted mustang at steady cruise in OD (it was an auto) at 65mph inside the car with both windows up and got 89Db
Rowing through the gears from stop sign to stop sign in town, windows up, inside the car it averaged 76 Db
Havnt found anyother tests besides that one, so I guess I'll have to buy a Db meter or go bug my friends at the local stereo shop to test it.
Mine has the same headers and X pipe, but I have different, quieter mufflers with no tailpipes.
You guys should take a Db reading inside the car at a steady 65 in 5th gear
