I'm confused - just got off the phone with EBC and they say they do not make pads for the 225.....
Old Mar 19, 2001 | 03:08 PM
BigTT's Avatar
Member
Default I'm confused - just got off the phone with EBC and they say they do not make pads for the 225.....
How can this be???? The dust is driving me nuts.... How is it that others on this forum have installed the EBC on the 225's???? am I missing something???? I spoke with a guy named Joseph @ EBC and he said they only support the 180..... Argh..... did I say the brake dust is driving me nuts?!?!?!?!??
Old Mar 19, 2001 | 03:17 PM
PGTT's Avatar
Default Though I don't have the EBC pads, here are the part numbers that I have documented...
EBC pad #'s - Fronts: DP21114, Rears: DP21230
Progressive Group (800) 905-6687 (<---recommended by OcTTober)
Old Mar 19, 2001 | 03:34 PM
BigTT's Avatar
Member
Thanks - but those are the numbers from EBC's web site... apparently only for the 180's....
Old Mar 19, 2001 | 03:35 PM
Rennen's Avatar
Elder Member
That's not true....I've got a 225 and I have EBC Green Stuff pads that fit fine
Old Mar 19, 2001 | 03:43 PM
BigTT's Avatar
Member
Default OcTTober, do you have the p/n's you used?
The guy I spoke with gave me no options once I said that I had the 225.... as if they did not want to offer the current pads... could it be because the wear sensor connector makes it a non-direct replacement???
Old Mar 19, 2001 | 03:49 PM
Bahookie's Avatar
Default PGTT, here are the Mintex part numbers you asked about in a prior thread....
This is what's on my invoice from APR :
Mintex Red Box front brake pads with sensors. MDB1531AF
Mintex Red Box rear brake pads. MDB1191AF
hth....
Old Mar 19, 2001 | 03:52 PM
MichaelTT's Avatar
Senior Member
To repeat OcTTober...DP21114 Fronts and DP21230 rears...and I assure you that I have a 225...
Old Mar 19, 2001 | 03:56 PM
PGTT's Avatar
Excellent! Thanks! And this is for a 225 TTQC, yes?
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 19, 2001 | 04:13 PM
PGTT's Avatar
And to repeat me as well.
Old Mar 19, 2001 | 04:18 PM
Rennen's Avatar
Elder Member
Default Not off hand, but I think the ones the others have given must be ok
Go to Progress Auto's site. They're who I used and they found them for me.
<a href="http://www.progressauto.com" target="_new">Progress Auto</a>
