how hard is it to install a forge valve...?(more)
But I don't recommend the Dremel for the small vacuum hose clamp... unless you have a real steady hand.
Just lop off the "bulge" with the Dremel--hold the cutting edge parallel to the flat side of the clamp. The Dremel will cut off the bulge, and never even touch the hose. Then twist the clamp at the bulge, the edges will pop through the gap, and the clamp will come loose. Then cut through the clamp and it's history. Happy Forging!
