Window control with remote?
Old Mar 27, 2001 | 11:17 PM
1T42T (aka ZZ CETT)'s Avatar
Member
Default Window control with remote?
I see there is a VAG code for this- what does it
do? How does it work, actually?
Just got back from my 5K service (it's ~4
hours away to the dealer) and I forgot to bring
the secret list of codes, so I will need to go
back to have this done. My main motivation is the
auto-lock/unlock function. I can do this and
keep the "safety lock" function, right?
But that's OK, they broke an air vent trying
to re-align it for me (I knew I shouldn't be
that picky...).
5k in about 2 months- at this rate, my service
work will be done in about 14 more months!:>
Scot
Old Mar 28, 2001 | 04:06 AM
MichaelTT's Avatar
Senior Member
Default Yes the codes do really work...but they are a secret that very few of us know...
There are quite a few combos...if you want remote window control, horn sounds/lights flash with security arming and automatic door lock (when car hits 15 mph) and unlock (when you pull key out of ignition then code is 15996 and if you all the above and one touch unlocking of both doors (default is one touch unlocking per door) then code is 15992.
Old Mar 28, 2001 | 04:41 AM
SecuriTT's Avatar
Junior Member
Default Here is the page of codes for the coupe.
<ul><li><a href="http://www.geocities.com/MotorCity/Boulevard/8062/ttvag.html">http://www.geocities.com/MotorCity/Boulevard/8062/ttvag.html</a</li></ul>
Old Mar 28, 2001 | 06:25 AM
catmando's Avatar
New Member
Mine was programed at club meet, go up or down with remote.
Old Mar 28, 2001 | 06:51 AM
dropTTop's Avatar
Junior Member
Are the codes different for the Roadster?
Old Mar 28, 2001 | 06:57 AM
225TTR's Avatar
Senior Member
Yes. Any particular code you are looking for?
Old Mar 28, 2001 | 07:26 AM
hoTTub's Avatar
Member
Could you post the codes for the remote window function on the TTR
Old Mar 28, 2001 | 07:27 AM
SecuriTT's Avatar
Junior Member
And I have the VAG software if you're near Brewster, NY (next to Danbury, CT)
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 28, 2001 | 07:49 AM
225TTR's Avatar
Senior Member
Default In a previous post, I posted the following:
Use 15992 for:
1 touch unlock of both doors
Horn sounds when arming
Lights flash when arming
Automatic door lock/unlock (at 15mph & when key is removed)
HOWEVER, I see that Michael posted this for the coupe (so one of us is mistaken). I have all the paperwork at home, but will double-check this evening. On the AudiWorld site, there is a section under Technical where you can go to the codes details, but both the coupe and roadster hyperlinks point to the same document (so one of them is incorrect). It's been like this for quite some time and has been reported, but for some reason hasn't been fixed. (Bottom line: I'm pretty sure that what I posted at the beginning of this message is correct, but I'll double-check later today.)
Old Mar 28, 2001 | 08:08 AM
Ebb Vicious's Avatar
Junior Member
Default i don't see why they would be different, my friend recoded my TT coupe the other day using ...
the docs found here on audiworld.
...dave
