Engine internals 225 vs. 180 differences?
Old Mar 28, 2001 | 08:02 AM
Jim TT's Avatar
Default LarryTT and Exttreme checked ALL part numbers and there was NO diff. However John S pointed out that
while replacement parts may indeed be the same, the parts used in manufacturing may be different. I know that this is the case with some Honda Motorcycles for example. So until a 180 and a 225 are taked apart and each part measured, we don't know.
Old Mar 28, 2001 | 08:03 AM
Larrytt's Avatar
Elder Member
Default pistons are different to account for the difference in compression ratio
one is dished one is flat topped.
Old Mar 28, 2001 | 08:17 AM
joe@vwvortex's Avatar
Default What was the source of the part numbers? Etka 5.0 ?
Etka is not always correct. I doubt that this is correct. According to all published reports by Audi and other technical papers I've read - there are several differences internally, included uprated main bearings, piston oilers (don't know if those are on the 180 though), pistons - which were already mentioned, as well as the external differences. However, as we all know - the 1.8T has undergone several changes over the past couple years - and I'm not quite sure if those changes to the lower HP versions were carried over to the higher HP versions - or if they existed in the higher HP prior to trickling down to the lower HP ones.
Old Mar 28, 2001 | 08:49 AM
Jim TT's Avatar
I don't know, but I do know that other than pistons there was no difference.
Old Mar 28, 2001 | 09:47 AM
Shahak's Avatar
New Member
Default Engine internals 225 vs. 180 differences?
I know Audi doesn't publicize these details, but does anybody know about differences between the 180 and 225 engine internals? Aside from the obvious (K04 turbo, twin coolers), are the cylinders, valvetrain, gasket, camshaft, etc. any different? Also, any noteworthy tranny differences (aside from the extra gear)?
Thanks in advance,
Shahak
Jay Quinn
Jun 13, 2020 12:27 PM
kiwibert
Feb 19, 2005 06:27 AM
aTTaboy
Jun 23, 2004 04:28 PM
Quattromaniac
14
Apr 29, 2002 08:34 AM
juliem
Jul 22, 2000 10:05 AM
