Will 235/45-17 tires work on 17x8 rims on the TT?
Old Mar 28, 2001 | 03:28 PM
Dave in NJ's Avatar
New Member
Default Will 235/45-17 tires work on 17x8 rims on the TT?
I've narrowed my wheel choices down to two: The OZ Volcanos or just keeping the stock 6-spoke coupe wheels. 18" and above are out of the question for NJ driving (we're densely populated and equally pot-holed). The recommended tire size for the 17x8 Volcanos is the standard Audi fitment of 225/45-17. In looking for a set of Sumitomo HTR ZII tires to wear with the new wheels, I find that size is out of stock, but there are plenty of 235s. Since the wheel is rather wide at 8", would the 235s be a comfortable fit or are there problems with this combination?
Thanks,
Old Mar 28, 2001 | 03:46 PM
RobbyTT's Avatar
Senior Member
Default Keep in mind, you'll get 12 less complete rotations per mile with the higher sidewall...
I don't think that is enough to really throw of you guages but just know that.
Also, are you talking about 235/45 on the stock 6 spoke 17" wheels?
Old Mar 28, 2001 | 03:58 PM
pockeTTs's Avatar
New Member
235/45-17 tires are wider than stock, not taller
Old Mar 28, 2001 | 04:06 PM
Tron (///M)'s Avatar
Re: 235/45-17 tires are wider than stock, not taller. Exactly what I was thinking.
Old Mar 28, 2001 | 04:11 PM
RobbyTT's Avatar
Senior Member
Default Nope, they are taller! 0.2" to be exact
The first number 235 is the width, the 45 means the sidewalls are 45% the width. Thus if the width increases with the same ratio (45) they get taller.
Old Mar 28, 2001 | 04:32 PM
smallTTs's Avatar
Member
Default RobbyTT is right on. I'd wait for the 225/45's to come back into stock.
Try this link for an explanation. There are other links to easily compare sizes.<ul><li><a href="http://www.tirerack.com/tires/tiretech/size.htm">http://www.tirerack.com/tires/tiretech/size.htm</a</li></ul>
Old Mar 28, 2001 | 04:35 PM
pockeTTs's Avatar
New Member
Whadya know...never knew it was a ratio. Can ECU correct for this?
Old Mar 28, 2001 | 04:36 PM
RobbyTT's Avatar
Senior Member
I don't think so but I could be wrong...
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 28, 2001 | 04:39 PM
RobbyTT's Avatar
Senior Member
Default Actually, here's a question for all: There is a diff. of 0.1" in total wheel/tire diameter
between the 205/55R16 and the 225/45R17 options. Which setup is the car calibrated to?
Dave in NJ's Avatar
New Member
Default Yes, you're right (re: aspect ratio) and no...
I wasn't thinking of the 235's on the stock wheels, but on the 17 x 8" Volcanoes. Thanks for the reply and reminding me about the aspect ratio. For some reason, I have a mental block when it comes to tire sizes.
Cheers,
