OT: IE5 Question
Of course its not critical to have all my messages on to this PC, as they are all on my home desktop, but it would be nice.
Any help would be appreciated.
...first, you must update your old machine to be at the same rev level for IE, OE, etc as the Win2k machine, or vice versa. Meaning if you have IE 5.5SP1 on the old machine, and IE 5.0 on the new, update the new to 5.5SP1. Which sucks if you don't have a high speed connection, I hope you do.
Then, start up OE. Do a Tools-> Options -> Click the tab that says Maintenance. Click the store. Should show a directory similar to c:\windows\application data\identities\{some gobbletiy gook that doesn't make sense with lots of goofy 0-34987e2r-394 type stoff in it surrounded by these }
Start up windows explorer. Browse to that directory (just match up the first few chars, should be only one there unless you created another ID for OE at any time) COpy contents to Zip disk or something big, should be a few MB in size depending on how much mail you have saved.
Then, go to new machine, do the same thing, close OE, find the directory, and copy the entire contents into that folder.
Start up OE, if everything worked, all the old email should be there. I just did this a few weeks ago when formatting the hard disk of my wifes machine, worked like a champ.
Hope that helps.
I know the difference between IE/OE...just a slip of finger, a fade of the brain. I'm just starting to learn the annoyances...I mean nuances of 2000...everything is in a different place than in 98. This is my work machine and unfortunately we don't use OE as our mail client (this is my personal mail) so I don't have the intimate familiarity I have with Lotus Notes which is our mail client. I will file this info away because another version of 2000 will be forthcoming in the future which means another reimage.
Thanks again for your help.
Moving notes is easy, copy all *.nsf, *.dsk and *.id and yer done.
I wrote it down too, so when I need it the next time its there.
Thanks again ;-)
