DV from Stratmosphere...
Old Mar 29, 2001 | 12:41 PM
FriscoTT's Avatar
Junior Member
Default DV from Stratmosphere...
Anyone buy the forged DV from Stratmosphere? I read the installation instructions and it seems easy...is it really THAT simple? Plus, does the DV really make that much of a difference? Seems like everyone here recommends replacing the DV almost immediately.
Thanks
Old Mar 29, 2001 | 12:43 PM
hoTTub's Avatar
Member
Default Yes it is that easy....
The hardest part is getting the oem hose clamps off and you might have to wrestle with that for a while put the rest is plug and play.
Yes it is recommended for the simple fact that the OEM are very prone to failure, not all of them...just most of them.
Old Mar 29, 2001 | 01:20 PM
FriscoTT's Avatar
Junior Member
Thanks, guess I'll order it now!!!!!!
KK's TT's Avatar
New Member
Default Re: Yes it is that easy....
I went through 4 Audi/Bosch DVs before installing the Forge. The good part was the dealership used standard hose clamps (as supplied with the Forge DV), so installing the Forge was even easier.
Old Mar 29, 2001 | 02:09 PM
joe@vwvortex's Avatar
Default I had my dealer replace my bad DV just so he would install regular hose clamps
which made the switch a less than 5 minute job.
Old Mar 29, 2001 | 05:49 PM
TTom TTR's Avatar
Default My wife said the box arrived today. Course it'll be Saturday, after school, after it cools off.....
...before I attempt it. I'm NOT auto-mechanically inclined. My Father did a bad training job. Usually consisted of him yelling and screaming, me hiding, and handing tools and then getting yelled at when said tools fell down in the engine compartment.
Old Mar 29, 2001 | 06:12 PM
case's Avatar
New Member
Default After installing the new DV, does one need to reset the ECU?
And if so how?
kodeTT
Apr 23, 2004 11:21 AM
GoTToGo
Aug 26, 2003 06:13 PM
IPsychL2
Jan 13, 2003 08:54 AM
Jabx
Aug 30, 2001 12:43 PM
ButchieTT
9
May 22, 2001 04:50 AM
