Has anyone else had the following problem?
The code that the computer is giving is
17536 P1128 035
Bank 1, mixture adaptation system too lean.
Any ideas would be greatly appreciated, since at this point I have absolutely no faith that this dealer has any idea what he's doing.
FWIW: Corrective action printout for the GTI is:
1)Check oxygen sensor and oxygen sensor control before and after catalyst
2)Check fuel pressure regulator and residual pressure
3)Check mass airflow (MAF) sensor [same p/n for 180 TT & VR6]
4)Check intake system and vacuum lines for leaks
5)Check fuel injectors and EVAP cannister purge regulator valve output
6)Check air intake screen(if equipped) and air filter for blockage. [have you changed filter?]
7)Check exhaust system for leaks [do you have cat-back?]
8)Check Secondary Air Injection (AIR) system for leaks (if so equipped)
My $.02
