Dyno theory . . .
In the case of my "Trollmobile-Under-the-bridge-GT" there is always talk about resetting the computer after mods - or waiting for the beast to "re-learn" the situation. I know from testing that after a mod (and even "re-setting") that performance continues to improve after several runs.
So: Are you changing chips and things between runs? Is the dyno environment different from real life? (air flow might be a big factor) Does the TT computer continue to adjust with changing imputs?
To tell the honest to God truth, I would be amazed if tests showed closer results. (Mfg. variances, chip changes?, intercooler temps could all influence results.)
Very interesting stuff. smallTT, comments please?
No to 'real life'...although large fan was pushing air over front of car (for cooling purposes) it did not duplicate a car going 75+ mph...thus less ram and cooling effect in the dyno.
Yes ECUs do adjust to environmental factors and the dyno computer adjusts readings to SAE.
As I posted earlier this morning I found the one example that I showed to be IMHO well within appropriate %age deviation.
So far not much is surprising.
I'm quite interested in how Dynojet does the 4 wheel attachment. Their website is a tad vague.
I'd guess it's another inertia wheel not physically connected (chains, belts, etc) to the main roller and measurements are added to main to get total. 4wd has always been a big problem for chassis dynos.
I'm positive a lot of discussion, figuring and conjecture will come from the results of these tests. Having hard data makes it worthwhile.
I'll keep reading and thinking.
If you haven't included it, wheel and tire combinations for each TT would be interesting to know. So would tire pressures.
Still thinking.
