ATTN: All those dyno'd or interested in dynoing... your dyno #'s are off
Dyno runs are to be done in a 1:1 gear ratio (ie 4th gear is your 1:1 on a 5speed, 3rd is 1:1 on an auto or 3 spd and *edit* apperantly 5th gear is your 1:1 on the 6 speed TT) The reason you run this way is because there is too much variation on gearing between different trannies. On average a 3rd gear is going to be at about 1.34:1, around there.
When runs are done in 3rd you get readings that are high by whatever gear ration 3rd is off from 1:1. I've been around dyno's for a long time... I've dyno'd my car , my dads car , friends cars... FWD to RWD... 6 speeds to 3 speeds, 5 speed auto's to 2 speed powerglides. I help a freind run the dyno down here, but i've pretty much been exposed to how they work for years and years and years.
And another.... 10% drivetrain loss is a little wishfull... Built race trannies (read supper efficient) dont even get 10% loss. You'd be lucky if its 15% for a fronttrack... most likely closer to 20% fwd and 25% awd
anyquestions... email or post.
Its as close as your gonna get. Regardless all dyno runs are to be made in 4th gear anyways... thats how dyno's are setup.
and 5th and 6th ARE both overdrives
Do you see how far off third gear has thrown the runs though? 1.429.... all the hp numbers are that much higher
