Redline Mtl helps shifts! (long)
Old Apr 15, 2001 | 01:20 PM
catmando's Avatar
New Member
Default Redline Mtl helps shifts! (long)
Changed oem tranny oil to Redline MTL, Big improvement in smoothness in every gear. Notice it the very first shift, However i bought a new pair of NIke air shoes and made the mistake of wearing them home and crunched 2nd gear almost every time, i have found that my shifts vary with the shoes, the Nike 's are 1.5 inchs longer than any other shoes i have even tho they are the same size inside. It takes size 10.5 to = a size 9 acording to salesman. This throws everthing off. As we know everytime someone complains of 2nd gear problems we all tell them to move the seat closer. This is what i did today, I have the seat exactly perfect for everyhing else but felt that i had to push the clutch to deep to get a good 2nd gear shift so i made a exact duplicate copy of the clutch pedal that is 1 half inch thick. I taped it over the pedal with a black straping tape really good and then covered it with a slip resistant tape. The idea is that now everytime i depress the pedal it is going in a additional half inch more than it was before.On my first test of this i found that even at 6000 in first i did not grind 2nd in 6 attempts, before even shifting at 5000 i would sometimes grind. If this continues to work out i may make a better looking part. Too bad the oem part is not adjustable.
Old Apr 15, 2001 | 02:36 PM
Haywood Jablome's Avatar
New Member
Re: online source?
Old Apr 15, 2001 | 04:41 PM
catmando's Avatar
New Member
Default Re: online source?
redline .com , but could never get answer on line or or 1-800 # found it at local (Tampa) speed shop.
Old Apr 15, 2001 | 07:07 PM
New Member
Re: thanks.
Old Apr 15, 2001 | 10:36 PM
Lloyd of the Rings's Avatar
Default Actually you get Redline Oil at......
Very good website and very responsive to email and phone questions<ul><li><a href="http://www.redlineoil.com">http://www.redlineoil.com</a</li></ul>
Racht
Audi R8
11
Jul 19, 2008 12:41 PM
(R)S4 SmokedU /-///
Nov 24, 2004 04:58 AM
palewhitemale
Oct 9, 2004 01:54 PM
dimo
Sep 29, 2003 09:24 AM
