Shock/Brake/Disc replacers - no warranty concerns?
I guess voiding your suspension/brake system warranty doesn't bother most of you?
Not trying to be Mr. AoA here, just curious...
Not a flame, just my thoughts.
Sure I'd love the Stoptechs and Bilsteins, exhaust etc but I just don't know.
I'm thinking along the same lines as Evan right now. I won't risk the engine warranty just yet, but shocks seem like a pretty mild risk. If I were to swallow a valve, no way they can blame it on shocks!
Remember that shocks are velocity driven. No velocity = no damping. Also, bump damping is usually way less than rebound damping, for lots of reasons. Any low pressure or non-gas shock should be able to be closed by hand, albeit slowly.
There is a school of thought that says because high-pressure gas shocks always have an upward (rebound) force due to the high pressure, they actually INCREASE body roll during turn in. Here's the rational:
Stiff rebound control usually retards raising of the inside suspension during rapid turn in (velocity sensitive remember) and therefore helps limit body roll during the transient turn in period, so the car feels 'quicker'. The high pressure gas directly counteracts this by trying to raise the unloaded inside. Curious, huh? High-pressure gas shock makers usually avoid this topic. Of course, low-pressure gas shock makers don't.
Some 'inertia valved' gas shocks have VERY stiff low velocity rebound control, and only moderate bump and rebound control at higher velocities, so they affect turn in, but not impact bumps ('outies').
Going over 'innies' (potholes) the stiffer rebound keeps the wheel from dropping into the hole and the resultant large bump force when it reaches the far side. Soft ride over small bumps, but good roll control and good control over large bumps. Not perfect, but effective.
OEM 'Sport' suspensions usually have significantly increased rebound damping, and slighlty increased bump damping, or the ride over small irregularities would be unacceptable. Aftermarket shocks usually have slightly stiffer bump and greatly stiffer rebound control(damping)for the same reasons.
Did you ever notice that single adjustable shocks adjust rebound only? It's the more important of the two. Double adjustables are rare and costly.
I fully endorse aftermarket shocks if you want to change the ride/handling. I'd only buy top brand names (Eibach, Bilstein, Koni, Sachs, Penske, Carrera, etc.) Some are private-labelled, but produced to their own specs. What's important, IMO, is that the damping be specific for the application.
My $.02.
