Michael, Jeff, other 'Milltekies'-- Shade tree mechanic doing well, but a few questions...
1) First of all, on your systems, I assume you go from stock cat outlet ==> into reducing collar ==> into Milltek center ==> into rear muffler. The new clamps-- seem to tighten down really well on the large OD of the front end of the center pipe... but since the reducing collar is a smaller OD, the clamp just won't tighten enough-- flops around! I made a stainless shim from the spare collar, and cranked it tight, but it still leaks. Did you guys get one small and one large clamp, or what?
2) On my system, the center only goes into the rear muffler an inch and a half. No leaks there, but its as though the center is too short. Same for you guys?
I didn't use tape or compound on the connections... figured I'd try the clamps first. Any advice?
I also gave up on the flat clamps and just used regular muffler clamps. Their roundness seemed to "bite" into the pipe and clamp it down much better.
yeah the center section doesn't overlap with the rear section a whole lot on mine too.
i'm sure using sealant would get rid of your leaks, but it is a messier install - something 2take in2 consideration seeing how beautifully polished your exhaust is!
do u have the straight center pipe in now? or the resonated center? if u don't mind, i'd love 2hear how the straight pipe sounds in person. i work in sunnyvale and would love to hear how it sounds after u install it.
-t
