OT: Fuel gauge problem
Anyone ever had this happen?
Right now my fuel gauge is _completely_ broken (ran out of gas and it still says full). Now, down to half a tank and still says full.
Next service appointment I'm going to have it replaced.
AoA has released a statement concerning the gas gauges for the A4 in which the contact points of the sensor unit in the gas gauge can mis-read the level of fuel based on the sulfur content of the gasoline. You can replace the sensor units all you want, but eventually the sulfur content will build-up and most likely you'll have the same problem.
OK ... here's my fix. LOWER the sulfur content of your gas! How? Go to your local Target or KMart and go to the automotive section and purchase a bottle of "STP Gas Treatment" - usually costs $0.79 per bottle. Put a bottle of this stuff in your tank before you fillup and the cleaner gas should help the contact points of the sensor unit.
I also usually put in a bottle of "Outlaw" Octane boost for good measure - helps with the gas mileage.
In any event, I HAVE NOT HAD ANY PROBLEMS WITH MY GAS GAUGE SINCE DEPLOYING THIS FIX. I SWEAR!
I would recommend that you try this for the next 3 or 4 gas fillups. After that, you can use a bottle once a month.
Tammi
I'm in a bad mood, sorry... my car is doing it's best Exxon Valdez impersonation - only with gas..
