Anyone with fwd 5spd shift problems! , i solved mine!
Old Apr 19, 2001 | 04:56 PM
catmando's Avatar
New Member
Default Anyone with fwd 5spd shift problems! , i solved mine!
On earlier post i told how Redline MTL improved all gears but i still had problems at times with 2nd and how i had taped a 1 half inch copy of clutch pedal on to increase the distance, after 2 days of stop and go i was so happy with the results i made one out of steel to accept the orginal pad and screwed it into place , only diff is that it adds 5 eights inch to travel and is even better. fell free to email me for details if you want to try.
Old Apr 19, 2001 | 05:40 PM
Haywood Jablome's Avatar
New Member
Default Re: You don't mean to say all of the problems are because TTers aren't clutching?
roflao x 1000000000000000000000000000
Old Apr 19, 2001 | 05:44 PM
AkRascal's Avatar
Default This was the topic of discussion about a year ago and yes catmando's solution is valid.. maybe
not all clutch/tranny problems, but in some cases, yes.
Old Apr 19, 2001 | 06:08 PM
New Member
Re: Phew!, Rascal, how are the lights up there? (Borealis) thanks
Old Apr 19, 2001 | 06:21 PM
catmando's Avatar
New Member
no, but i always noticed that unless i had the seat in exactly the right spot i somestimes had 2nd gear problems if i shifted to fast, also everthing changed depending on which shoes i wore. This led me to believe that the clutch was so sensitive that unless it was pressed clear to floor grinding could occur. My change just helps to insure complete clutch release.
Old Apr 19, 2001 | 06:26 PM
AkRascal's Avatar
supposed to be good, but it is daylight now past my bed time... so I dunno...
Old Apr 19, 2001 | 07:44 PM
gdewiTT's Avatar
Junior Member
Default We're flying up there for the weekend just to see the lights and AKRascal.
Not many hours of night left in Fairbanks, now. Sunset isn't until almost 2200.
snowchaser
9
Feb 14, 2008 06:38 AM
ROMTT
14
Sep 13, 2005 05:39 PM
Raullopy
Feb 8, 2004 06:30 PM
Reaction26
Jun 1, 2003 09:42 AM
BillG
Jan 24, 2000 09:17 AM
