tire failure
Old Apr 24, 2001 | 04:35 PM
GttF's Avatar
Default tire failure
Tire practically separated, sidewall from tread. Was cruising about 70mph and smelled burning rubber. 60 seconds later I was hobbled.
What is 1st step for warranty replacement- Dealer or tire shop? Only 5k miles. Do I go for 4 new ones?
Old Apr 24, 2001 | 05:15 PM
RogerL's Avatar
Junior Member
Default What kind of tire?
If it's bridgestone RE040, try the dealer first. They might cover it, although it's not the "normal" failure that's covered.
Otherwise, tires are the one thing Audi doesn't cover, you'll probably have to go to the tire dealer.
You should be okay replacing just 1, but have them put it on the back.
Old Apr 24, 2001 | 05:25 PM
GttF's Avatar
Default u got it Bridgestone
Bridgestone REO40's. Real confidence builders1
Old Apr 24, 2001 | 05:41 PM
HersheyTT's Avatar
New Member
Default Re: What kind of tire?
is there a lot of history on this tire and a response from Audi?
I am noticing significant wear on different parts of all 4 RE040's and am rotating at every 5K. I remember the dealer reinforcing the tire warranty as strictly non-Audi.
Old Apr 24, 2001 | 05:59 PM
Steve C2's Avatar
Default 040s are being replaced by Audi
Check with Audi -- 040s have known problems and dealers have been told to replace questionable tires. I would venture that one that has already failed is questionable:-)
S4NoRice
Jul 5, 2001 01:39 PM
niTTany lion
Apr 8, 2001 08:16 AM
noeltykay
Sep 29, 2000 10:00 PM
Jim De Arras
Feb 19, 2000 12:51 PM
Lisa
Wheels & Tires Discussion
Jan 5, 2000 12:53 PM
