TT wheels and tires.. Please help..
Old Apr 25, 2001 | 12:24 AM
Johnny Bravo's Avatar
Default TT wheels and tires.. Please help..
Hey Im new to you guys. Im an a4 member.
Ive seen a few tt's with super huge tire setups i.e 255's.
Im running 255 all around on my a4 (Hi my name is johnny and im a canyon junkie)
What is the advantage of runing such wide tires on the tt?
For those who are looking for a very capable track car, would you use 245's all around. can the front fender accept a 255 or a 245 tire with out rubbing.
Since most tt's are fwd, and some have haldex, is the sole reason for big rear meat a cosmetic one?
how bad does the car Push with such wide tires in the rear, on a mostly fwd car.
Can 245's be mounted all the way around.
I plann on getting a tt, so please help me get started in the right direction.
Could i go with a 245 35 18 tire all around.
regards
Old Apr 25, 2001 | 02:32 AM
OTOF's Avatar
Elder Member
You have backwards....think the majority of TTs (at least on this Forum) are quattro.
Old Apr 25, 2001 | 07:26 AM
Ebb Vicious's Avatar
Junior Member
nice attempt at starting a flamewar/being insulting.
Old Apr 25, 2001 | 07:45 AM
Auto Union Jack's Avatar
Senior Member
Default It is not cosmetic and 235 is all you can get up front....
I run 225 up front to not overnumb the steering. I also run 255's on my quattro with a 19mm rear sway to equalize the understeer of the staggered design negating chassis roll after the fact. My belief (and I expect to be flamed for not following the sheep inspired mod culture on this forum ) is that the Haldex engages sooner due to understeer at the front tyres. The rear anti-roll bar negates from the chassis and I get a quicker turn in from the staggerred set up and a stronger push out of turns due to the engaged Haldex and the contact patch dynamics of the 255's. ESP off always of course. The Boxster S and all Porsches are staggered this way at about the same ratio. The TT has the same wheelbase as the Boxster, but is 60/40 in weight. Engaging quattro ASAP is the equalizer.
aviattor.3
24
Jun 4, 2007 12:00 PM
sloduck
Mar 10, 2006 02:53 AM
Jason Chen
Pacific Northwest Discussion
10
Aug 3, 2004 05:30 AM
Russell Arthur
Jul 8, 2002 03:57 PM
wsimpson
Wheels & Tires Discussion
May 12, 2000 09:37 AM
