DG Coupe returns from dealer with new LF wheel bearing . . . smiles again !
Old Apr 25, 2001 | 11:44 AM
driviniTT's Avatar
Default DG Coupe returns from dealer with new LF wheel bearing . . . smiles again !
Smooooth sailin', Forge hums, S02's stick like crazy. Evolution autocross school this weekend - Phase 1, lots of seat time. Gonna be faster . . !
Old Apr 25, 2001 | 11:45 AM
PGTT's Avatar
Good news! supercoupe rides again!
Old Apr 25, 2001 | 12:14 PM
sandra's Avatar
Member
tell me about your wheel bearing please ! did it cause vibration ? was damaged ? if so, how ?
Old Apr 25, 2001 | 12:24 PM
RogerL's Avatar
Junior Member
Default Hum, that makes 2 of us with LF bearing failures.
Mines a 00 180. Replaced at 25K.
It was a bit noisy, a bit like tire noise whine, otherwise not noticable.
Yours?
Old Apr 25, 2001 | 12:34 PM
jackTTar's Avatar
Member
Default Most Excellent!!! Nice meeting you and your wife at the FH2O lunch.
The 5-Series is probably happy to have those pictures removed. Enjoy the autocross school.
Old Apr 25, 2001 | 06:46 PM
driviniTT's Avatar
Default not sure how it was damaged . . .
we think it may have been from not tightening the CV joint nut after the clutch job. Dealer doesn't think so, says it sometimes happens, unrelated to clutch job. The wheel was actually loose on the axle (+/- 15° ! . .gasp . . .!). After retightening the assembly, we test drove it and could hear the bearing. It sounded like a digeredoo - mechanic said that's a bad bearing, go home. It was damaged by the wobble from the axle nut coming loose. I also had just put on new tires the day before, and did hear a different sound then, which I thought it was the tires' new road noise. It was kind of a grinding, that I (LOL) mistakenly called the sound of the fierce grip. Ooops. Otherwise it handled OK, except for this kind of lurch when I applied the brakes, which I thought was a soft pedal, because sometimes it was fine . . . ah, hindsight . . . What do you hear/feel? Take it to the dealer, and have a mechanic drive with you in the car, and interpret.
Old Apr 25, 2001 | 06:48 PM
driviniTT's Avatar
thanks for rallying 'round ! How was the drive back?
Old Apr 25, 2001 | 06:54 PM
driviniTT's Avatar
Default just put on new S02's and figured it was the *new* road noise . .
damage occured because of wobble from loose axle nut - any idea why yours went?
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 25, 2001 | 07:07 PM
driviniTT's Avatar
Default Still need to run the River Drives loop . . . . pic is from Sat lunch (sending you hirez one)
<center><img src="http://pictureposter.audiworld.com/14718/ttday12s.jpg"></center><p>
Old Apr 26, 2001 | 04:20 AM
RogerL's Avatar
Junior Member
Default Re: just put on new S02's and figured it was the *new* road noise . .
Not sure what caused mine. Best guess is something happened during the ESP retrofit.
hanoking
Nov 20, 2006 11:45 AM
Mr Paul [T-28]
Nov 14, 2006 09:41 AM
treehunter
10
Apr 14, 2005 12:59 PM
S4NoRice
Jul 6, 2003 12:20 PM
RogerL
Mar 12, 2001 04:25 PM
