Marcus/Sean/Jenner...does this combo work on the 225...18X8 with 235/40/18? Thanks
I reccommend a lightweight 18" wheel and rubber with good wet traction. 235 width is also dependant on rim width and a 235 wide tire will be wider on a 8.5" rim than an 8.0"
Only thing that will change is at 101.7mph your speedometer will read 100mph at 66.105mph your speedometer will read 65mph. Something to keep in mind if you get pulled over...
