Question re: LLTEK air intake installation....
Old Jun 26, 2001 | 04:33 PM
BuddhisTT's Avatar
New Member
Default Question re: LLTEK air intake installation....
Just installed the air intake but having problems with parts fitting correctly. The cone filter and the air inlet tube from the car does not fit properly. It's kinda loose and has a gap on the bottom side of the tube and filter. Is that normal or am I not trying hard enough? Is it suppose to fit "snuggly" together? Can someone help me out...thanks so much in advance.
Old Jun 26, 2001 | 05:33 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default I had some problems with this too......
<center><img src="http://pictureposter.audiworld.com/13940/lltekintake1.jpg"></center><p>It takes quite a bit of force to get the snorkel (inlet tube) into the filter end. Push it in (about 1 inch) until the ridge hits the filter cap. Once in, it will stay provided the filter maintains some pressure on it toward the fender wall. The snorkel itself is bolted on with a bushed grommet, is not securely mounted and will wiggle about. Check out the pic and let me know if there are any questions. Mine went together loose the first time too.....
Old Jun 26, 2001 | 05:55 PM
BuddhisTT's Avatar
New Member
Default Called LLTEK.......
and they told me it is suppose to fit tightly,,just need a little playing around and adjusting. I'm not too convince because I've been playing around with it for 3 stinking hours.
Old Jun 26, 2001 | 06:00 PM
Larrytt's Avatar
Elder Member
Default Force fit it in . ..
It takes a little biut of work, but it will pop in. I did two installs already and they will pop in place. Once in it does not pop out after it is installed in the car.
Old Jun 26, 2001 | 07:08 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Trust us, it WILL go in....
Old Jun 27, 2001 | 05:30 AM
mr. zero knew's Avatar
If you don't mind me asking, how much $$$ with s/h? Thanks.
Old Jun 27, 2001 | 01:34 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default There was a group buy a while ago....>>
Don't know the current pricing. Call Neil at 1-888-go-lltek<ul><li><a href="http://www.lltek.com">http://www.lltek.com</a</li></ul>
RallyAudi
Jun 21, 2011 06:49 AM
Zwoobah
Audi Original "S" Cars
9
Jun 21, 2007 05:12 AM
TCU_TT
15
Mar 13, 2006 02:47 PM
Smitty: Kriegswagen
May 4, 2005 12:56 PM
HeyZeus
May 2, 2005 03:41 PM
