I want to compare the temp gauge in the dash with the digital one on the AC controls..
Old Jun 27, 2001 | 10:36 AM
Ryan E.'s Avatar
Junior Member
Default I want to compare the temp gauge in the dash with the digital one on the AC controls..
What is the correct code on the AC controls for this temp reading? I have the list of codes, but I am not sure which one corresponds to the water temp gauge on the dash (next to the gas gauge).
When I was at the track, my TT was the only one that didn't get hot. I want to make sure my gauge is working correctly. Thought I would compare the 2 temp readings.
Thanks in advance.
Ryan
Old Jun 27, 2001 | 10:41 AM
evan's Avatar
Senior Member
Default 49c is Coolant Temperature. 51c is "Engine Temp" whatever that means....
but 51c reads 90*C all the time unless the temp goes +/- 10*C.
49 is what you want to use.
Old Jun 27, 2001 | 10:42 AM
steve TTQ's Avatar
New Member
Default Re: I want to compare the temp gauge in the dash with the digital one on the AC controls..
Code is 49C for temperature.
Old Jun 27, 2001 | 11:18 AM
Ryan E.'s Avatar
Junior Member
Default Thanks everyone. Is this the correct way to see the codes?
Press and hold the recirculation button, Then press the manual flow control up arrow. You should see a 1c. Continue pressing up until I get to 49c. Then press the recirculation button again to se the value.
Is this correct?
-Ryan
Old Jun 27, 2001 | 11:29 AM
Larrytt's Avatar
Elder Member
That is correct.
milla290
Jul 26, 2007 09:19 AM
fignewton
Mar 30, 2004 10:18 AM
pearlaudi7
Feb 26, 2003 06:41 PM
fredneckian
Nov 23, 2001 11:09 AM
