I know we went through this before but where is the temp gauge supposed to read?
Old Jun 28, 2001 | 03:33 PM
Laguna's Avatar
Old Jun 28, 2001 | 03:37 PM
KenD's Avatar
New Member
Straight Up at 12:00
Old Jun 28, 2001 | 03:39 PM
Laguna's Avatar
Default It's at 1:00! Time to worry?
I swear it was always at 12 before I looked at it this afternoon. Does it creep up and then come down for some unknown cosmic reason?
Old Jun 28, 2001 | 04:19 PM
evan's Avatar
Senior Member
Default sometimes. I think that gauge has a mind of its own...
I've followed the coolant temp readings that can be displayed on the climate control readout. For me, 89*C-93*C is normal while driving, and idling in traffic may be between 93*C and 101*C. Sometimes the gauge needle goes to 1:00 when the coolant temp climbs over 100*C... and sometimes it doesn't!! I wouldn't even begin to worry unless the needle goes high and stays there.
Read actual coolant temps by doing this: press and hold recirc button on climate panel; press up-vent arrow. 1c appears on display. use the temp control **** to set the number to 49c. press recirc. voila! coolant temp in degrees C.
Old Jun 28, 2001 | 04:22 PM
Laguna's Avatar
Evan! Yo da man! Thanks so much! Putting paranoia aside and reaching for a Cosmo.
Old Jun 28, 2001 | 05:26 PM
TTurbo's Avatar
Default If you sit idle in traffic long enough it will go to 1:00 until the auxiliary fan kicks in.
I can tell you from experience after sitting in Houston traffic for quite some time with the air on. If it is not too hot, turn the a/c off until you get going again so that you do not tax the engine anymore than possible. -Doug
Old Jun 28, 2001 | 05:45 PM
Lone Starr (Ivan)'s Avatar
Elder Member
Only 225's have the second fan, correct?
Old Jun 28, 2001 | 05:49 PM
nighttrain's Avatar
New Member
2001 TTR 255 - 12 o'clock when driving, 1 o'clock when standing still
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 28, 2001 | 06:04 PM
gtt's Avatar
gtt
I completely forgot that feature - I need to save your post ;-)
Old Jun 28, 2001 | 07:19 PM
OTOF's Avatar
Elder Member
Just remember what happened last time you did that....post no pictures...stay out of dog house!
