HElp with REDRILLED RIMS (fill and Drill) Anyone have any experience with it?
Old Jun 29, 2001 | 08:09 AM
turbo1's Avatar
New Member
Default HElp with REDRILLED RIMS (fill and Drill) Anyone have any experience with it?
Good or bad.........
Old Jun 29, 2001 | 08:29 AM
hoTTub's Avatar
Member
Default It better be one kick *** set of wheels for what you plan to do....
Why are you doing this?
Are they not available in your bolt pattern?
Are they really expensive wheels that you can get cheap?
What is the reason you want to do this?
Old Jun 29, 2001 | 08:41 AM
turbo1's Avatar
New Member
its for a one sweet wheel that i cant get in the bolt pattern........
Old Jun 29, 2001 | 09:17 AM
MAX@edgeracing.com's Avatar
Member
Default Bad
It will void your warranty (on the wheels) dont mess with structural integrity of a wheel.
Slight drilling is some times not a big deal, what bolt pattern is the original wheel? drilling more than 1 or 2mm is VERY risky, take it from me i should know
MAX
Old Jun 29, 2001 | 11:32 AM
Jason Chen's Avatar
Try getting wheel adaptors instead. www.wheeladaptors.com(maybe with s or with/o)
Old Jun 29, 2001 | 11:58 AM
smallTTs's Avatar
Member
Default Bad idea. REALLY bad, especially (fill and Drill).
Adapters are a possibility, but they will probably screw up the offset beyond what is reasonable/safe. They are about 25 mm thick in order to change bolt pattern. Unless the wheels you are choosing have 55 mm or more offset, which few do, you are out of luck.
IMO, it doesn't matter how cool the wheels are, an unsafe mounting or modification is a no-no.
My $.02
Milpitas2.7T
Sep 4, 2006 02:46 PM
619Motoring
Sep 10, 2004 06:43 PM
Mexican Audi (Shane)
Florida Discussion
Jan 5, 2004 09:23 AM
JRSCGSR
Sep 22, 2002 05:26 AM
Kyle K: TampaS4
Wheels & Tires Discussion
Mar 12, 2002 05:43 PM
