FMIC is finally stealth black! Pics inside....
Old Jun 29, 2001 | 03:46 PM
evan's Avatar
Senior Member
Default FMIC is finally stealth black! Pics inside....
Got my FMIC back from the anodizing shop.... here it is before I took it in...
<IMG SRC="//www.evan.com/tt_pics/fmic/evan_fmic.jpg">
And here are three pics after coating it...
<IMG SRC="//www.evan.com/tt_pics/fmic/fmic_black_01.jpg">
<IMG SRC="//www.evan.com/tt_pics/fmic/fmic_black_02.jpg">
<IMG SRC="//www.evan.com/tt_pics/fmic/fmic_black_03.jpg">
Coating isn't perfect, but I didn't expect it to be. Shop warned me that there might be places where the coating wouldn't stick-- white specks you see in pics. Bottom line, they did a fine job of achieving my goal-- make that shiny silver IC black, without impacting heat dissapation qualities. Cost: $135.
Old Jun 29, 2001 | 03:52 PM
joe@vwvortex's Avatar
Looks great Evan, i've often thought about doing that if I go with a FMIC
Old Jun 29, 2001 | 03:59 PM
EloqnTT's Avatar
How did you get past the issue of coatng the insides?
Old Jun 29, 2001 | 04:03 PM
evan's Avatar
Senior Member
Default After discussion with second shop, decided it was a non issue...
in that the coating wasn't going to come off and end up in the engine. Essentially, the metal is now dyed black, so there really isn't a coating to flake... though it could fade over time. I just had them dip the whole part.
Old Jun 29, 2001 | 04:17 PM
Larrytt's Avatar
Elder Member
Default Then since it was dipped this means it can't chip, correct?
I like how it looks! Why didn't you have it done a shade of dark green to match the car? lol
Old Jun 29, 2001 | 05:01 PM
evan's Avatar
Senior Member
Default They said it can't flake or chip... I guess its a bit like colored metal...
a couple of the guys were hotrodders, and felt it wouldn't be a problem to coat the inside. If my engine self-destructs, I'll let you know. :-)
Thought about doing desert green, but it was enough hassle getting the damn thing done in black.
Old Jun 29, 2001 | 05:07 PM
PorTTland's Avatar
Member
Default The FMIC will actually perform better with the dark coating, same as refridgerator coils blacked.
Encyclopedia Britanica:
"The rate at which a body radiates (or absorbs) thermal radiation depends upon the nature of the surface as well. Objects that are good emitters are also good absorbers (Kirchhoff's radiation law). A blackened surface is an excellent emitter as well as an excellent absorber. If the same surface is silvered, it becomes a poor emitter and a poor absorber. "
Old Jun 29, 2001 | 05:08 PM
braTT Miller's Avatar
Junior Member
Default yep, they are changing the molecular makeup of the surface of the Al
...<ul><li><a href="http://wuarchive.wustl.edu/edu/arts/metal/TOC/finishes/anodize.html">link, not the best description but its ok</a></li></ul>
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 29, 2001 | 05:11 PM
überTT's Avatar
New Member
sweet, well worth the $$
Old Jun 29, 2001 | 05:16 PM
maddoTT's Avatar
Junior Member
We can see it--thats worth$$$$$$$$$$$
