When getting a nail in the tire, is it better to patch from the inside
Old Jun 30, 2001 | 04:42 AM
cellogig's Avatar
Default When getting a nail in the tire, is it better to patch from the inside
of the tire or get a plug on the outside? Also does the speed rating of tire get affected? Another words if the speed rating is 155mph. and then there is a repair on tire, is the speed rating still 155mph. or 0 mph.
Old Jun 30, 2001 | 04:45 AM
Skydive69's Avatar
Junior Member
Default Any time you repair a speed rated tire, that rating is compromised by a patch - no matter the
technique used. If you plan on driving over 120 (as I do too often), you will need a new tire to gaurantee your safety. If you drive "normally", you will be fine.
Old Jun 30, 2001 | 04:54 AM
hoTTub's Avatar
Member
SkyDive is right......go for the patch
Old Jun 30, 2001 | 05:07 AM
JustJeff's Avatar
Default Don't plug, patch. The 'squirm' factor is gonna affect the drivability...
Depending where the patch is, the 'squirm' of the tire can/will degrade the patch.
I've had this happen with a different car, but it's possible also with your conditions.
The plug will squirm also, and give you a better chance of loosing air, IMHO.
The plug is *easier and cheaper*, no question, but a good repair guy will put on a good patch.
5timeaudiowner
Jun 28, 2007 09:35 PM
Bruno_S4
Canadian Discussion
24
Oct 7, 2006 06:14 PM
A4wheelin
Dec 20, 2005 05:13 AM
Ulmer
9
Aug 27, 2001 03:11 PM
Hugh B
Oct 1, 2000 07:23 AM
