Floor jack advise - and Eibach Sports are finally on.
And the worst that could happen did last night. Big red releases by turning the handle - but it sticks sometimes. I had the front wheel off and needed to lower the car a bit to set the jackstands and the handle stuck, then all at once it let go and the car lowered leaving the rocker slammed on the jack, the brake rotor 1/4" from the floor. Luckily the damage to the rocker is underneath and out of sight - and also next to a drain hole so I was able to reshape it by using a tool pushed inside the rocker - still not perfect but you wouldn't see it unless I pointed it out.
So my need for advise is for a new low profile jack - sorry no Sear's crap - looking for a decent US made of course for a decent price. Any suggestions?
BTW, I was finally getting around to putting on the Bilstein Sports on the front when the incident happened. Since I already put on the Eibachs last year, the second R&R was much easier but I had to make a new strut spreader tool this time. Test drive was very positive - the Bilstein Sports actually ride smoother that the stock Monroe's. One interesting thing I did notice is that the front is now 1/2" higher than before - front and rear are now equal distance to the wheel arch ar 25 5/8".
